This command only initiates the search process. It does not return the actual GPS coordinates. To view the coordinates, execute the following command:show gps coordinates {on <DEVICE-NAME>}
Access Point — AP7662
gps search [start|stop] {on <DEVICE-NAME>}
            | gps search [start|stop] | Triggers the GPS hardware to start or stop the GPS coordinates
                                search process
 Note: Unless
                                    explicitly stopped, the GPS coordinates search continues at
                                    regular intervals.
| on <DEVICE-NAME> | Optional. Specifies the AP whose geographic coordinates are to be
                                determined. Use this option if executing the command on the
                                controller or virtual controller to which the AP is adopted.
 Note: If you do
                                    not specify a device name, the system initiates the search on
                                    the logged device. And if the logged device is not an AP7662
                                    model access point, an error message returns.
ap7662-8BDE4D#gps search start Started GPS Search, please check back after some time. ap7662-8BDE4D#
ap7662-8BDE4D#show gps coordinates GPS Search is in progress. Last location recorded at UTC time : Mon Apr 23 22:10:54 2018 : Latitude : 13.036N Longitude : 77.3827E ap7662-8BDE4D#
